Full Version: [ATV] [MBP] Thetvdb 404 due to missing language
13:22:06 T:2957324288 M:386879488 DEBUG: found match smb://ebony/databank/xbmc/tv/burn notice/season_02/burn.notice.s02e11.avi (s02e11) [[Ss]([0-9]+)[\.-]?[Ee]([0-9]+)([^\\/]*)$]
13:22:06 T:2957324288 M:386854912 INFO: Get URL: http://www.thetvdb.com/api/1D62F2F90030C...0/all/.zip
13:22:08 T:2957324288 M:386842624 ERROR: Server returned: 404 Not Found
That should be en.zip, I tried editing thetvdb.xml and also got a fresh one from svn and neither helped. The only way I can add new episodes to a show is to remove the show and re-add.
"scan for new content" also seems to work
This is due to a bug in your build. Make sure you set content on the folder _AND_ go in to the scraper settings. Set them to default.
You may have to set content to none, then switch back to tv shows in order for it to trigger the changes.
You're right. I recently installed Rev18004.
Your hint to use 'default settings' didn't work. At least not on Windows.
Any idea when this will be fixed or how I can fix it myself or what is the latest rev without this problem?
Thanks I will try that... when thetvdb isn't timing out. It looks like xbmc gives up after 5 seconds, can I configure that or is it in the binary?
Another thing already fixed - it's in the binary.
