2009-03-02, 23:43
I hope someone can give some pointers or tell me if this is a lost cause :-)
I have XBMC installed as per the minimal install instructions using Ubuntu 8.10 Server. I have an ATI Radeon 7200 installed on a ECS K7S5A mobo with a 1GHz Athlon.
The system worked beautifully while I had it connected to a monitor but now that I have it connected to only a TV via s-video or composite I lose any display after the initial splash screen. There is a flash of random video memory after about 23 seconds and then nothing. I can't even ping the machine let alone ssh in and see any logs.
Can anyone give any hints or help as to why a monitor connected via vga works but not a TV?
I can get into the PC when exhibiting similar symptoms if I specify an explict vga= mode on the kernel line in GRUB but I don't see anything specific in the logs. Mind you, I'm not sure what to look for. I'm guessing it's an X conf problem.
I got the Xorg.0.log for the TV only boot. It seems the same as a good boot but only up to an early point:
My good Xorg log with only a monitor connected continues on from here. The next line is:
Any ideas anyone?
xbmc@xbmc:~$
xbmc@xbmc:~$ cat Xorg.0.log.old
X.Org X Server 1.5.2
Release Date: 10 October 2008
X Protocol Version 11, Revision 0
Build Operating System: Linux 2.6.24-19-server i686 Ubuntu
Current Operating System: Linux xbmc 2.6.27-11-server #1 SMP Thu Jan 29 20:19:41 UTC 2009 i686
Build Date: 24 October 2008 08:00:16AM
xorg-server 2:1.5.2-2ubuntu3 ([email protected])
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Sat Feb 28 21:37:47 2009
(EE) Unable to locate/open config file
(II) Loader magic: 0x81d9a40
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.4
X.Org Video Driver: 4.1
X.Org XInput driver : 2.1
X.Org Server Extension : 1.1
X.Org Font Renderer : 0.6
(II) Loader running on linux
(--) using VT number 3
(--) PCI:*(0@1:0:0) ATI Technologies Inc Radeon R100 QD [Radeon 7200] rev 0, Mem @ 0xc0000000/0, 0xcfe80000/0, I/O @ 0x00009800/0, BIOS @ 0x????????/131072
(II) Scanning /usr/share/xserver-xorg/pci directory for additional PCI ID's supported by the drivers
(II) Matched radeon from file name radeon.ids
(==) Using default built-in configuration (39 lines)
(==) --- Start of built-in configuration ---
Section "Device"
Identifier"Builtin Default radeon Device 0"
Driver"radeon"
EndSection
Section "Screen"
Identifier"Builtin Default radeon Screen 0"
Device"Builtin Default radeon Device 0"
EndSection
Section "Device"
Identifier"Builtin Default ati Device 0"
Driver"ati"
EndSection
Section "Screen"
Identifier"Builtin Default ati Screen 0"
Device"Builtin Default ati Device 0"
EndSection
Section "Device"
Identifier"Builtin Default vesa Device 0"
Driver"vesa"
EndSection
Section "Screen"
Identifier"Builtin Default vesa Screen 0"
Device"Builtin Default vesa Device 0"
EndSection
Section "Device"
Identifier"Builtin Default fbdev Device 0"
Driver"fbdev"
EndSection
Section "Screen"
Identifier"Builtin Default fbdev Screen 0"
Device"Builtin Default fbdev Device 0"
EndSection
Section "ServerLayout"
Identifier"Builtin Default Layout"
Screen"Builtin Default radeon Screen 0"
Screen"Builtin Default ati Screen 0"
Screen"Builtin Default vesa Screen 0"
Screen"Builtin Default fbdev Screen 0"
EndSection
(==) --- End of built-in configuration ---
(==) ServerLayout "Builtin Default Layout"
(**) |-->Screen "Builtin Default radeon Screen 0" (0)
(**) | |-->Monitor "<default monitor>"
(**) | |-->Device "Builtin Default radeon Device 0"
(==) No monitor specified for screen "Builtin Default radeon Screen 0".
Using a default monitor configuration.
(**) |-->Screen "Builtin Default ati Screen 0" (1)
(**) | |-->Device "Builtin Default ati Device 0"
(==) No monitor specified for screen "Builtin Default ati Screen 0".
(**) |-->Screen "Builtin Default vesa Screen 0" (2)
(**) | |-->Device "Builtin Default vesa Device 0"
(==) No monitor specified for screen "Builtin Default vesa Screen 0".
(**) |-->Screen "Builtin Default fbdev Screen 0" (3)
(**) | |-->Device "Builtin Default fbdev Device 0"
(==) No monitor specified for screen "Builtin Default fbdev Screen 0".
(==) Automatically adding devices
(==) Automatically enabling devices
(==) No FontPath specified. Using compiled-in default.
(WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
Entry deleted from font path.
(==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/100dpi/:unscaled,
/usr/share/fonts/X11/75dpi/:unscaled,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType
(==) ModulePath set to "/usr/lib/xorg/modules"
(II) Cannot locate a core pointer device.
(II) Cannot locate a core keyboard device.
(II) The server relies on HAL to provide the list of input devices.
If no devices become available, reconfigure HAL or disable AllowEmptyInput.
(WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
(II) No APM support in BIOS or kernel
(II) System resource ranges:
[0] -100xffffffff - 0xffffffff (0x1) MX[b]
[1] -100x000f0000 - 0x000fffff (0x10000) MX[b]
[2] -100x000c0000 - 0x000effff (0x30000) MX[b]
[3] -100x00000000 - 0x0009ffff (0xa0000) MX[b]
[4] -100x0000ffff - 0x0000ffff (0x1) IX[b]
[5] -100x00000000 - 0x00000000 (0x1) IX[b]
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
