I tried to get this beta work on a Eeetop (touchscreen) and failed so far.
I am able to boot the Intel version in decent boot time.
However, the display won’t show nothing, but different ‘clic’ sounds are played when using the keyboard. This makes me think it’s correclty loaded, and just a matter of grapics.
I hope to see it working anytime soon
Tell me how I could help.
I see it may come from the xorg.conf file to fit the specific eeetop resolution.
Here is a version, I've found to run correctly Ubuntu 8.10.
However, for me it doesn't fix the problem, xbmc won't start. "Can't open display error"
Quote:Section "ServerLayout"
Identifier "XFree86 Configured"
Screen 0 "Default Screen" 0 0
InputDevice "Touch0"
EndSection
Section "Device"
Identifier "Configured Video Device"
Driver "intel"
Option "monitor-LVDS" "LVDS"
Option "monitor-LVDS-1" "LVDS-1"
Option "NoDCC"
EndSection
Section "InputDevice"
Identifier "Touch0"
Driver "evtouch"
Option "device" "/dev/input/evtouch"
Option "MinX" "1"
Option "MinY" "1"
Option "MaxX" "4096"
Option "MaxY" "4096"
Option "ReportingMode" "Raw"
Option "Emulate3Buttons" "false"
Option "Emulate3Timeout" "50"
Option "SendCoreEvents" "on"
Option "MoveLimit" "0"
EndSection
Section "Monitor"
Identifier "Configured Monitor"
EndSection
Section "Monitor"
Identifier "LVDS"
# Option "Ignore" "True"
EndSection
Section "Monitor"
Identifier "LVDS-1"
ModeLine "1366x768" 76.00 1366 1386 1396 1560 768 770 773 793
EndSection
Section "Screen"
Identifier "Default Screen"
Monitor "Configured Monitor"
Device "Configured Video Device"
DefaultDepth 24
Subsection "Display"
Modes "1366x768"
EndSubsection
EndSection
There should be a log file for xorg in the /var/log directory. If you take a look in there it should shed some light as to what X is doing, if you can post it on pastebin or similar that would might be helpful also.
Thank you for your help.
I'm a nexbie in linux / xbmc live world ...
I've managed to get command line using safe mode.
However the /var/log directory won't have any xorg file log.
I've only files like auth.log, lpr.log and user.log to name a few.
no further clues on that topic ?
What videocard does the machine use?
