2009-03-03, 18:30
[updated to version 2.0]
This mod for the PM3.HD skin will show your CD & DVD cover art in a nice case. I am by no means a skinner and my image graphic skills are practically non-existent.
So, with that beings said, there might be some flaws here and there (haven't found one yet though).
All in all (IMHO) the results are very pretty.
The DVD case looks like this:
And the CD case like this:
Some examples of this mod in other views:
http://img530.imageshack.us/gal.php?g=tvshowlist.jpg
installation is easy:
- extract the 2 images from the zip file to the 'media' subfolder of the PM3.HD skin
- extract the xml files to the '720p' subfolder (you might want to back up the 720p subfolder first!)
Download:
You can download this mod here or there.
If you're not using the default PM3.HD skin, but the PM3.HD_TV_Movies Mod by Jezz-X, get it here or there.
If you're using the PM3.HD_TV_Movies Mod by IllumiNaughty, get it here or there.
changelog v2.0:
- cleaned up the code a bit
- slightly modified the images
- removed empty cases
- updated the xml files to SVN r19100
- added support for:
- list view
- thumbnail view
- media info view
- dvd thumb view
- home window
- slideshow
- visiluasation
- menus
- tv shows
todo:
- change cd case to match the dvd case
- add support for:
- 3d coverflow
- album info view
- dvd info view
Download:
changelog v2.0:
- list view
- thumbnail view
- media info view
- dvd thumb view
- home window
- slideshow
- visiluasation
- menus
- tv shows
todo:
- add support for:
- 3d coverflow
- album info view
- dvd info view
