2009-09-01, 18:14
2009-09-03, 16:13
Here is my cooling sulution for the Zotac board
Still w8ing for my case.
http://www.silentpcreview.com/forums/vie...hp?t=55204
2009-09-04, 00:40
Hello I have just bought the geforce 9300 itx wifi REV 01
I have found that i have to power cycle my pc a few times in order to get the picture on my tv. this is the same on both my samsung lcd and my toshiba.
any ideas why this is.
it is the same through vga
when i connect my laptop via vga to these tvs i get a picture immediately
cheers
cheers
2009-09-04, 17:16
gui Wrote:ok i got back a new ZOTAC GeForce 9300 - ITX WiFi,but still having same problem regarding the memory slot plus various other things like will not detect the dvd drive sometime.
i noticed that the stock intel cpu cooler it bend slightly the motherboard once fitted,if the cooler does not touch properly the cpu surface could this give problemsmy psu is 150w would this be ok to run e5200+hdd+dvd drive+3 fans?is driving me mad
Hi, try the following
1 - Boot with only one DIMM
2 - Enter BIOS Setup
3 - Go to Frequency / Voltage Control
4 - Set MEM Voltage Control at 2.0v
5 - Save, disconnect, insert the second DIMM, and it should work fine
2009-09-05, 15:50
has anyone been able to wake this mobo using wake on lan / wi fi etc have a ipod touch i would like to use but not very well versed in wi fi etc
cheers
cheers
2009-09-06, 09:38
can anybody confirm is this mainboard linux (Ubuntu) 100% compatible ?
I have a few quetstions :
- is suspend working ?
- is the MB very hot ?
- which driver doesnt runs. (example: sound, audio etc.)
regards
yanardag
regards
yanardag
2009-09-07, 11:22
yanardag Wrote:Hi,
regards
yanardag
I'm having some problems with the wifi driver, but there's info on the ubuntu forum on how to compile this driver.
From what I've seen, with a Pentium Dual Core E2160, the CPU is at 40º and the Nvidia Chipset at 60º, at an ambient temperature of 30º
2009-09-09, 16:44
rfdomingos Wrote:Hi, try the following
this mob is getting to my nerves.
it worked for a few on/off and now still having booting problem:mad:
will try some different brand i guess.
