Full Version: core dumb on boot
Hi
since the last update does the XBMC write core dumbs. Sometimes the whole system even hangs up on it.
i installed XBMC on top of xubuntu. The strange thing is that 90% of the time the system works just fine even though it wrote the dumb.
can somebody point me in a direction what is not set up right on my system?
thanks
the Dumb:
PHP Code:
#0  0xb8077430 in __kernel_vsyscall ()
(gdbbt
#1  0xb75408a0 in raise () from /lib/tls/i686/cmov/libc.so.6
#2  0xb7542268 in abort () from /lib/tls/i686/cmov/libc.so.6
#3  0xb757e16d in ?? () from /lib/tls/i686/cmov/libc.so.6
#4  0xb7584454 in ?? () from /lib/tls/i686/cmov/libc.so.6
#5  0xb75864b6 in free () from /lib/tls/i686/cmov/libc.so.6
#6  0xb79999de in SDL_DestroyMutex () from /usr/lib/libSDL-1.2.so.0
#7  0xb79487dc in ?? () from /usr/lib/libSDL-1.2.so.0
#8  0xb796d916 in SDL_VideoQuit () from /usr/lib/libSDL-1.2.so.0
#9  0xb79427d5 in SDL_QuitSubSystem () from /usr/lib/libSDL-1.2.so.0
#10 0xb794285e in SDL_Quit () from /usr/lib/libSDL-1.2.so.0
#11 0xb79430ef in ?? () from /usr/lib/libSDL-1.2.so.0
#12 <signal handler called>
#13 0xb74341b6 in XUngrabPointer () from /usr/lib/libX11.so.6
#14 0xb7976b85 in ?? () from /usr/lib/libSDL-1.2.so.0
#15 0xb798286b in ?? () from /usr/lib/libSDL-1.2.so.0
#16 0xb79828ee in ?? () from /usr/lib/libSDL-1.2.so.0
#17 0xb796cff7 in ?? () from /usr/lib/libSDL-1.2.so.0
#18 0xb796d0bc in ?? () from /usr/lib/libSDL-1.2.so.0
#19 0xb796d93a in SDL_VideoQuit () from /usr/lib/libSDL-1.2.so.0
#20 0xb79427d5 in SDL_QuitSubSystem () from /usr/lib/libSDL-1.2.so.0
#21 0xb794285e in SDL_Quit () from /usr/lib/libSDL-1.2.so.0
#22 0xb7543d89 in exit () from /lib/tls/i686/cmov/libc.so.6
#23 0xb7436fcd in _XDefaultIOError () from /usr/lib/libX11.so.6
#24 0xb797f587 in ?? () from /usr/lib/libSDL-1.2.so.0
#25 0xb7437062 in _XIOError () from /usr/lib/libX11.so.6
#26 0xb743f135 in ?? () from /usr/lib/libX11.so.6
---Type <return> to continue, or <return> to quit---
#27 0xb743f985 in _XEventsQueued () from /usr/lib/libX11.so.6
#28 0xb743fa12 in _XFlush () from /usr/lib/libX11.so.6
#29 0xb7416f61 in XFlush () from /usr/lib/libX11.so.6
#30 0xb7975dae in ?? () from /usr/lib/libSDL-1.2.so.0
#31 0xb79797b2 in ?? () from /usr/lib/libSDL-1.2.so.0
#32 0xb797aaab in ?? () from /usr/lib/libSDL-1.2.so.0
#33 0xb7947f9d in SDL_PumpEvents () from /usr/lib/libSDL-1.2.so.0
#34 0xb7948467 in SDL_PollEvent () from /usr/lib/libSDL-1.2.so.0
#35 0x0852c740 in CXBApplicationEx::ReadInput (this=0x8a76c50) at XBApplicationEx.cpp:343
#36 0x082aca7d in CApplication::FrameMove (this=0x8a7dc60) at Application.cpp:3012
#37 0x0852cb13 in CXBApplicationEx::Run (this=0x8a7dc60) at XBApplicationEx.cpp:234
#38 0x0852f3dc in main (argc=1, argv=0xbfc79494) at XboxMediaCenter.cpp:117
polarber Wrote:Hi
since the last update does the XBMC write core dumps. Sometimes the whole system even hangs up on it.
i installed XBMC on top of xubuntu. The strange thing is that 90% of the time the system works just fine even though it wrote the dump.
thanks
the Dump:
PHP Code:
(gdbbt
It's a core dump not a core dumb..
Sorry I couldn't resist correcting you.
Follow the link blkmgk provided. You haven't given enough info to even begin debugging. A complete guess would be that you don't have proper 3d support or you're running with <24bit color depth.
thanks althekiller
it was the 24 bit setting. I just installed xbmc on top of a mythbuntu system. I thought all settings would be fine for xbmc.
To the rest I will try not to be to funny anymore with dumbs... and thanks for the link next post will be complete
