Sorry if this is a simple questions, but I have just moved from PMIII to MediaStream and I can't find the 'Favorites' menu. I have used PLEX on my Mac which uses the same skin and it lists 'Favorites' on the Home page, but on my Xbox I don't have this as an option under skin settings. Does anyone have any ideas?
Press right on the System menu item I believe.
You can also edit your keymapping.xml to set your own trigger. I use 7 on my remote and activate my favourites from almost anywhere within the skin. Very handy indeed.
D
JustMeD Wrote:You can also edit your keymapping.xml to set your own trigger. I use 7 on my remote and activate my favourites from almost anywhere within the skin. Very handy indeed.
D
Hi, what did you add to be able to trigger the fav menu?
