Full Version: stuck at the xbmc setup menu, same with aeon skin too
hello i am stuck at xbmc setup menu
i am trying all diffrent buttons on the mouse and keyboard to try and get to the home screen but i cant leave the xbmc setup menu screen, if i try and click right mouse button once the screen just blinks once
i have tried resetting the settings but that doesnt help, when i click on reset it doesnt look like anything happens
this is a beautiful skin and would love to try it, but i cant try it if im just going to be stuck at the xbmc setup menu screen
thank you
this also happens with the aeon skin
sarahandkevin Wrote:hello i am stuck at xbmc setup menu
thank you
Tried the 'Escape' key yet?
yeh he tried that as i suggested in his other thread. but the esc key should bring you straight back to the main menu. Or it should?
paul Wrote:yeh he tried that as i suggested in his other thread. but the esc key should bring you straight back to the main menu. Or it should?
Yeah, I found the other thread after that reply. Perhaps a screenshot will assist us in helping?
The description is a little ambiguous.
Yeh i agree it's hard to advise without knowing the exact problem as you say a screenshot would be helpfull
Try unplugging the mouse and using the keyboard to navigate. I had a problem with strange mouse behavior with these skins.
