Full Version: last.fm stops after one song?
when I start playing a last.fm stream it stops after one song. It continues as soon as I press stop/play. Anyone else having this problem?
Cheers,
Beau
Debug log.
http://forum.xbmc.org/showthread.php?tid=34655 you're going to want pastebin for it. Hopefully the log will show where it's failing to get data or some other error. Version etc. probably needed as well since the code is constantly changing as the devs stomp bugs and add features...
Have the same problem ... it's strange because according to log file the playback is started but nothing happened ... i have to press pause/play to make it play next song
Here's xbmc log http://pkrzaczk.pastebin.com/m1826cace
Thx,
Pawel
pkrzaczk Wrote:Have the same problem ... it's strange because according to log file the playback is started but nothing happened ... i have to press pause/play to make it play next song
Thx,
Pawel
Just started using the feature - I have the same problem. VDPAU SVN 18309
xnappo
pkrzaczk Wrote:Here's xbmc log http://pkrzaczk.pastebin.com/m1826cace
l
Please only post FULL debug logs.
xnappo Wrote:Just started using the feature - I have the same problem. VDPAU SVN 18309
VDPAU branch is only for testing that feature, we will not support other problems on it. Please try this on the linuxport tree.
