(**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
(==) NVIDIA(0): RGB weight 888
(==) NVIDIA(0): Default visual is TrueColor
(==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
(**) NVIDIA(0): Option "ExactModeTimingsDVI" "True"
(**) NVIDIA(0): Option "UseDisplayDevice" "DFP-0"
(**) NVIDIA(0): Option "AddARGBGLXVisuals" "True"
(**) NVIDIA(0): Option "ModeValidation" "DFP-0: NoMaxSizeCheck, NoHorizSyncCheck, NoVertRefreshCheck, AllowNon60HzDFPModes, NoMaxPClkCheck, NoVesaModes, NoXServerModes, NoPredefinedModes"
(**) NVIDIA(0): Option "FlatPanelProperties" "Scaling = Native"
(**) NVIDIA(0): Option "DynamicTwinView" "false"
(**) NVIDIA(0): Enabling RENDER acceleration
(II) NVIDIA(0): NVIDIA GPU GeForce 8200 (C77) at PCI:2:0:0 (GPU-0)
(--) NVIDIA(0): Memory: 524288 kBytes
(--) NVIDIA(0): VideoBIOS: 62.77.24.00.08
(--) NVIDIA(0): Interlaced video modes are supported on this GPU
(--) NVIDIA(0): Connected display device(s) on GeForce 8200 at PCI:2:0:0:
(--) NVIDIA(0): OEM 37'' TFT-TV (DFP-0)
(--) NVIDIA(0): OEM 37'' TFT-TV (DFP-0): 165.0 MHz maximum pixel clock
(--) NVIDIA(0): OEM 37'' TFT-TV (DFP-0): Internal Single Link TMDS
(II) NVIDIA(0): Mode Validation Overrides for OEM 37'' TFT-TV (DFP-0):
(II) NVIDIA(0): AllowNon60HzDFPModes
(II) NVIDIA(0): NoMaxPClkCheck
(II) NVIDIA(0): NoMaxSizeCheck
(II) NVIDIA(0): NoHorizSyncCheck
(II) NVIDIA(0): NoVertRefreshCheck
(II) NVIDIA(0): NoVesaModes
(II) NVIDIA(0): NoXServerModes
(II) NVIDIA(0): NoPredefinedModes
(II) NVIDIA(0): Assigned Display Device: DFP-0
(==) NVIDIA(0):
(==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
(==) NVIDIA(0): will be used as the requested mode.
(==) NVIDIA(0):
(II) NVIDIA(0): Validated modes:
(II) NVIDIA(0): "nvidia-auto-select"
(II) NVIDIA(0): Virtual screen size determined to be 1920 x 1080
(--) NVIDIA(0): DPI set to (304, 304); computed from "UseEdidDpi" X config
(--) NVIDIA(0): option
(WW) NVIDIA(0): 32-bit ARGB GLX visuals require the Composite extension.
(WW) NVIDIA(0): Disabling 32-bit ARGB GLX visuals.
(--) Depth 24 pixmap format is 32 bpp
(II) do I need RAC? No, I don't.
