Full Version: Skin Sounds, Where to find more actions/windows to add sounds to?
Hi, I have been messing around with the sounds a little bit and it's very straight forward to change the sounds to what ever you want. Either by editing the sounds.xml or just renaming the .wavs.
Where would i look to find more Actions or Window titles to map additional sounds to? (duno what the exact term is for these but they control what the sound is attached to)
Paybac
http://blackmarket.ictcsc.net/index.php?page=sounds
Here you can download some soundpacks.
Edit:
Open the sounds.xml from example Cyber Ninja and learn from it and customize or use it.
I downloaded one of the sound packs, and had a look at the sounds.xml, The particular one had some web address that didnt work but gave me the correct terms for what i was looking for. So i could wiki it
http://wiki.xbmc.org/?title=Keymap.xml#A...le_actions
http://wiki.xbmc.org/?title=Window_IDs
Paybac
