I would like to add to the info list view , run time and genre values
Where I should do that,
I just installed XMBC after using Media portal with MediaStream,
In the MP i modified the moviingpicture.xml file with i cant find it here
depends exactly what you are trying to edit. my guess, since it seems like videos, you should look in ViewsCommon.xml or ViewsVideo.xml.
let me know if that's what you were looking for.
Thanks,
it looks that the viewvideo.xml is the file,
but it very different from the movingpictures from Media Portal
Do you know how I can add to the movie info list view
two rows below the year
one for genre and the second for tun time value
can you throw up a mock screenshot of what you are trying to do. it doesn't have to look pretty at all. just use paint if you have nothing else...
Attached is snapshot from my Media portal moving picture that i modified,
Im trying to do the same in the XBMC
for some reason i cannot post attachments...
Open Includes.xml and find next paragraph
<include name="InfoListItemDetailInfo">
<posx>456</posx>
<posy>0</posy>
<width>104</width>
<height>42</height>
<align>left</align>
<aligny>center</aligny>
<label>$INFO[ListItem.Label2]</label>
</include>
Change $INFO[ListItem.Label2] to $INFO[ListItem.Genre] $INFO[ListItem.Duration]
