Full Version: [RELEASE] Lucky 7 pre-2.0 (XBMC Game)
Hello All,
Here's one of my most successful achievements, I am astonished myself.:p
Script: Lucky 7
Version: pre-2.0.0 (Destiny)
Date: 13-03-2009
Creator: Frost
Developed: On XBMC for Windows
Url: http://code.google.com/p/passion-xbmc/
SVN Url: http://passion-xbmc.googlecode.com/svn/t...ipts/Lucky 7/
Language: Mutli for a moment (English/French)
Download:
1. Use Installer Passion-XBMC http://forum.xbmc.org/showthread.php?tid=42612 and a developer of installer
2. Or use a SVN client and get the repos passion-xbmc http://passion-xbmc.googlecode.com/svn/trunk/ which includes Lucky 7
Description:
Small game for simulates the Lucky 7 "Slot Machine" that can be found in casinos.
Virtual currency of course. Smile
I leave Lucky 7 Version 1, you can still play in the Info dialog there is a button "PLAY"
NB: The script requires a recent release of XBMC revision approx.: 18000
NB2 : I have not account the memory used by the script, is it consumes a lot and I recommend it not for the XBox.No
You can test if its XBox plant but the cause is probably lack of memory.
Oh forgot I was the best in my opinion, the skin of the script presents a first ever in a XBMC skin.
I called the CUBE Cool, it is 3D and animated is not smooth, but the look is good.
A short comment or suggestions are welcome
French support here: http://passion-xbmc.org/le-coin-des-utilisateurs/lucky-7-pre-2-0-(xbmc-game)/
cheers
Frost
you do some amazing things with python and the skinning engine.
That's really impressive, very nicely done !
I can confirm that it DOES work on the xbox using T3CH XBMC 2009-03-04 SVN rev18221.
Great looking script. thanks a lot!
Yes, the interface is just amazing. Never seen somethin like that before in a script on XBMC.
Frost is a magician! (he is also the guy who did the biggest part of the GUI of the installer Passion-XBMC, do you remeber the caroussel? It is Frost too. Lucky us! Smile )
So Frost what will be your next surprise? Wink
i use it with xbox.
only problem is wrong remote control mapping.
when i press 'select' with remote control, spinning starts and info screen appear in same time.
with pad it works ok.
when i press infobutton with remote control, info screen appear twice.
but game works great
Nuka1195 Wrote:you do some amazing things with python and the skinning engine.
You are my virtual teacher.:p I studied your creations, which include the latest features of XBMC. Thanks for your creations which is good referenceWink
@mikko70
Sorry I have not optimized the remote because I have not.
I just entered the keymap which is based on the action of XBMC.
you are kottis, member of passion google code?
Look and edit file ../Lucky 7/resources/libs/keymap.py
and you have rights to commit
frost
