I was unhappy with some things in Intrepid, so I reverted to Hardy (fresh install). However, XBMC is having issues playing sound for anything other than digital - mp3's and most avi's don't play sound (video is fine). Tested the files in mplayer and they're fine.
Could this be caused by some of the more recent svn changes?
Read the stickies. There is one that covers this.
ALSA bug.
fasteddy Wrote:I was unhappy with some things in Intrepid, so I reverted to Hardy (fresh install). However, XBMC is having issues playing sound for anything other than digital - mp3's and most avi's don't play sound (video is fine). Tested the files in mplayer and they're fine.
See this thread and in particular, this post:
http://forum.xbmc.org/showthread.php?tid=35901&page=3
Should get you back up and running.
xnappo
tslayer Wrote:Read the stickies. There is one that covers this.
ALSA bug.
I tried that. Didn't help. I assumed this meant I was having other issues. I'll try again, I suppose.
[Edit: Nope. Any other suggestions? Note that I am using hdmi rather than spdif. Also, I should have mentioned that the menu sounds work just fine. Odd...]
What version of ALSA? Oh and what video drivers? Both of those must be updated even on Intrepid to get proper HDMI sound - and then ALSA config files have to be dorked with <sigh>
BLKMGK Wrote:What version of ALSA?
1.019 via the Ubuntu forums script for ALSA, and 180.37 for NVIDIA. I'm using the same .asoundrc that I used in Intrepid (had none of these sound problems. I got rid of Intrepid for unrelated reasons).
tslayer Wrote:How about a debug log?
I'll try to get one together tonight.
Tried to play an episode of 30 Rock (.avi). Video fine, but no sound. Debug:
http://pastebin.ca/1369494
Ubuntu Hardy
ALSA 1.019 over hdmi
NVIDIA 180.37
XBMC linuxport rev 18831
Okay, so it turns out Pulseaudio is the culprit. I killed pulseaudio and files played fine. Interesting. PA behaved fine under Intrepid. I have libpulse-dev installed - I was under the impression pulse issues were mostly solved.
Sorry, no idea. I don't use pulse
It seems I posted too quickly. My issues are not completely solved, as DTS audio does not seem to be working (with or without PA). My receiver is not DTS capable, so I haven't selected it in xbmc audio settings (regardless of whether I do or not, it doesn't work).
Different issue...
So, create a different thread. And saying it isn't working doesn't help. Provide as much detail as possible (always pastebin the debug log!).
Actually, as it turns out, it was all the same issue. Everything was pulseaudio-related. I fixed it by copying over my .asoundrc and .pulse folder from the previous intrepid install (good thing I backed it up).
So if anyone is curious, here's how I solved it:
.asoundrc:
pcm.dmixer {
type dmix
ipc_key 1024
ipc_key_add_uid false
ipc_perm 0660
slave {
pcm "hw:0,3"
rate 48000
channels 6
format s32_le
period_time 0
period_size 1024
buffer_time 0
buffer_size 12288
pcm.!default {
type plug
slave.pcm "dmixer"
ctl.!default {
type plug
slave.pcm "dmixer"
~/.pulse folder:
daemon.conf:
default-sample-rate = 48000
default.pa (copied from /etc/pulse and appended the following to the end):
load-module module-alsa-sink device=dmixer sink_name=hdmi mmap=0
set-default-sink hdmi
set-default-source hdmi.monitor
default-sink
default-source
