is adding an image format a long hard process?
if you are not in a freeze yet. this could be useful for a skin i'm working on.
http://www.libpng.org/pub/mng/
we already support mng's - just not the actual animation
that was fast. anyway to support the animations?
i would use it for a mame plugin.
i don't expect it would, but if .mng animations worked in the thumbpanel that would be even better.
ok, i see you use cximage and mng is supported. but looking at your code. i guess you would have to do something like you did for animated gifs?
maybe after 904 you would consider it, but in the mean time should .mng be added to the acceptable image types?
i added it to advanced settings. though it's not necessary for me to use it as Listitem.Thumb. in hopes for an animated thumb display in my mame plugin.
Hello to all,
I posted my Question in the PM3HD Section too, but seems that nobody can answer me...
Therefore I am trying here again :
Can anyone tell em how ro use MNG Files (with Animation) in the Home Screen ?
Here my Original Posting :
[MOD] [PM3HD] Smiley Animated weather icons for the home screen
http://forum.xbmc.org/showpost.php?p=362132&postcount=1
(cause i dodnt want to Xpost)
Cheers,
Konstantin
You can't. MNG is not supported. A patch would be welcome.
Hello jmarshall,
thankyou for the Answer.
Here the Link to the MNG Code Libraries and Ports:
http://www.libmng.com/
Cheers,
Konstantin
