I'm running XBMC 8.10 (installed RPM from
http://fedorajunkies.com/index.php/XBMC) on Fedora 9 i386. When I try to play a video, it fails with:
Error
Playlist playback aborted
Too many consecutive failed items
Looking at the log, I find:
ERROR: Unable to load /usr/share/xbmc/system/players/dvdplayer/avutil-51-i486-linux.so, reason: /usr/share/xbmc/system/players/dvdplayer/avutil-51-i486-linux.so: undefined symbol: __wrap___fprintf_chk
ERROR: CDVDDemuxFFmpeg::Open - failed to load ffmpeg libraries
ERROR: OpenDemuxStream - Error creating demuxer
I've tried compiling from source, but haven't had any luck... the configure script fails to find -lmysqlclient even though it is installed.
Any help/suggestions would be greatly appreciated. Thanks in advance.
Thanks for the help. I was able to compile it from source, but unfortunately I'm still getting the same error when trying to play videos.
drivesoslow Wrote:To compile from source there is a symlink you need to create for mysql
http://forum.xbmc.org/showthread.php?tid=35594
jccheng Wrote:Thanks for the help. I was able to compile it from source, but unfortunately I'm still getting the same error when trying to play videos.
Are there any news? This problem prevents the use of XBMC on Fedora.
Same problem with latest XBMC and Fedora11, rpm from fedorajunkies (same problem with self-compiled packages):
ERROR: Unable to load /usr/share/xbmc/system/players/dvdplayer/avutil-49-i486-linux.so, reason: /usr/share/xbmc/system/players/dvdplayer/avutil-49-i486-linux.so: undefined symbol: __wrap___fprintf_chk
18:40:00 T:2917120880 M:1397940224 ERROR: CDVDDemuxFFmpeg::Open - failed to load ffmpeg libraries
18:40:00 T:2917120880 M:1397940224 ERROR: OpenDemuxStream - Error creating demuxer
I'm able to play videos with the built-in video player if I compile from svn. There is also an external player feature so that you can use mplayer, xine, vlc, etc.
marco2bb2 Wrote:Are there any news? This problem prevents the use of XBMC on Fedora.
jccheng Wrote:I'm able to play videos with the built-in video player if I compile from svn. There is also an external player feature so that you can use mplayer, xine, vlc, etc.
Thanks for the news! I'll try :-)
I compiled svn code, and now built-in player works well!
However, I did not find the external player feature in the UI. For me, it will be very useful, because for some material I need the mplayer feature to delay (negative or positive) subtitles (which I linked to a key on the remote), which is not presente in the built-in player.
Can you point me to this feature? Thanks
I just followed the directions from
http://wiki.xbmc.org/?title=HOW-TO_use_a...a_playback (specifically the "playercorefactory.xml method" section).
Hope that helps!
marco2bb2 Wrote:I compiled svn code, and now built-in player works well!
