HW: Gigabyte GA-MA78GM-S2H with onboard ATI HD3200 Graphic,
OS: Ubuntu 8.10 ( Intrepid), GNOME desktop
driver: fglrx driver 9.2 and 9.3 ( latest from yesterday )
SW: SVN Build of XBMC ( seen for sure from Build 18100 and up )
Problem: XBMC hangs during startup, also if ~/.xbmc is completly removed
( XBMC splash screen is seen , no more )
current workaround: going back to 9.1 and I can use xbmc again.
I have tried now 2 times to install ubuntu from scratch - no change.
Have someone the same expericense ? - it seems that I am the only one ...
The funny thing is, that I have installed exactly the enviroment ( incl. same HW) with the ATI 9.2 driver and there there is no problem
any idea or help appreciated !
I can confirm the problem, spend a few hours on the weekend but with not much success.
I'm on Jaunty with Catalyst 9.3 and xbmc hangs with/directly after splash. XBMC and X can't be killed afterwards, machine needs reboot.
Here's a thread where someone's trying the radeon drivers
http://ubuntuforums.org/showthread.php?t=1090098 but without success, too.
Funny thing is, that this bug has something in common with the "garbled fullscreen" bug some where seeing with fglrx: starting xbmc as root somehow works. IIRC someone said this has something to do with dri not enabled, but can't find the reference now :/
Log as user:
http://pastebin.ubuntu.com/140580/
Log as root:
http://pastebin.ubuntu.com/140581/
The difference I see it GL_VERSION = 2.1.8575 and then vsync seems to be handled differently
Thank you for this helpfull answer and the references ! And thanks to confirm this problem !
I can fully agree what you described. I am also familiar with the "garbled fullscreen" problem in the fglrx releases last year.
For me it seams that ATI is not testing against XBMC for a release !?
I'm running ATI with AMD 780G chipset (HD3200) and Catalyst 9.3 drivers reasonably successfully.
There was definitely a change in how VSync is handled between 9.2 and 9.3. I had the ATI VSync patch (
http://trac.xbmc.org/ticket/5951) applied. However, with that patch xbmc.bin was running 100% CPU even when idling.
Had heaps of problems getting 9.3 working. Seems like I was affected by the problems listed at
http://www.phoronix.com/forums/showthrea...069&page=4
No problems with any garbled screens though.
I'm running Mythbuntu 8.10 (XFCE, not Gnome). Catalyst Control Center has VSync Always On and VSync disabled in XBMC.
dteirney Wrote:I'm running ATI with AMD 780G chipset (HD3200) and Catalyst 9.3 drivers reasonably successfully.
Thanks, this gives some hope
dteirney Wrote:There was definitely a change in how VSync is handled between 9.2 and 9.3. I had the ATI VSync patch (http://trac.xbmc.org/ticket/5951) applied. However, with that patch xbmc.bin was running 100% CPU even when idling.
Had heaps of problems getting 9.3 working. Seems like I was affected by the problems listed at http://www.phoronix.com/forums/showthrea...069&page=4
Thanks for linking the ticket. Somehow missed it. Will try when I'm back home.
So you say XBMC runs (100% cpu with patch, normal without) with current svn and no lockups?
mind posting your xbmc.log to compare?
Just to post a short success note: Disabling vsync in XBMC did it.
Unfortunately XBMC starts in "always on", so normally you can not have it running on 9.3...
I can confirm that handling vsync from within XBMC creates the issue: If you start with a proper guisettings.xml with sync off and start toggling the gui control, XBMC hangs when "always on" is selected.
Had the freeze issue, it helped changing the vzync option.
But I wonder, does anyone else have the 100% cpu issue? I have it and can't get rid of it...
Ubuntu 8.04, ATI HD3200.
Any ideas what to do? Maybe I should try the patch mentioned earlier in this thread? But then I need to go back to catalyst 9.1?
Any other tips?
I also have this issue, will try to disable VSync, as soon as I figure out how. Funny thing is, I think this only happened because I'm connected to an HDTV with VGA (HDMI give me a black screen).
The reason I say that cause I install a clean copy of Ubuntu on this very machine, and the ATi 9.3 drivers and XBMC 9.04 alpha. I had no problems what so ever.
But when I tried to connect this PC to my HDTV with an HDMI cable, it never worked and I eventually screwed up the Xorg install, so I just reinstalled Ubuntu all over again , but connected to my Samsung T220 monitor.
After I got Ubuntu install again on this PC, I connected it to the HDTV again, but this time thought the VGA. Worked fine, so I kept it connected to the Samsung HDTV. I installed the ATi 9.3 drivers, then fixed Pulse Audio, then installed XBMC. When I start XBMC it just crashes at Splash screen and I have to reboot.
I'm runinng a BIOSTAR T-Serries TA790GX XE; AMD 64X2 5000+;4GB GSkill 1066; Wetern Digital 640GB 16MB cache HDD.
To disable vsync without loading xbmc: go to ~/.xbmc/userdata/ and open up guisettings.xml with a text editor. Search for "vsync" and change the value to 0.
I was having the same problem with catalyst 9.3 and ubuntu 8.04 on a gigabyte ga-ma78gm, until the fix described above.
That solved my problem.
Thanx jar72, wish I had seen you post 2 hours ago. I search the forums and the net and finally found where the guisetting.xml file was. But only after I saw althekiller post
http://forum.xbmc.org/showthread.php?tid=34655. It showed me where the debug log was, from there I knew the gui file was close by.
Thanks for letting me know what to set it to, that save me a lot of searching. Everyone just said simple disable it, but they never said how. I was debating using a 0 or the word disable. I wasn't sure sine there was a 2 there instead of a 1. What does vsync set to 2 do anyways?
Man, after all that, I'm REALLY gonna enjoy watching Lost tonight on my HDTV. I will keep trying to get HDMI to work later.
