Full Version: How do I delete my library and start over?
I would like to delete my library and start over. I only have a few things in it, but whenever I try to Clean It Up, I give up after an hour and only 25% done.
Also, side question... Where do I put the Advancedsettings.xml file talked about here: http://wiki.xbmc.org/?title=Advancedsettings.xml
It says to put it in "\UserData\", but where is that folder on an Apple TV? Do I need to create the folder too?
Thanks,
Indy
go into XBMC and in Userdata>Database>
in there you will find all the database files, if you only want to start over
with videos, delete MyVideos34.db and reboot your box or pc, then set the
content again and away you go.
if you are using XBMC on pc the database is in:
c:\Documents and Settings\Username\Application Data\XBMC\Database
remember Xtv is a skin thus the Userdata folder does not live there, it
is in the main folders of XBMC
hope this helps Smile
Perfect! That worked and I have a fresh, new library! Thank you!
