Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19
ah - i didnt know he wsa working on one ...
Angel when is that due to release?
Can Macro just add another Images section with the ability to use showcase and wall? Nox has that feature -
hell angel has just started work on it dont think hes even close to thinking bout a release yet .....he needs ideas and suggestions what to implement first , thou i already started xD
marco? you realize hes only a skinner not an xbmc dev xD...-.-'
p.s: no offense but nox sux -.-'
dugan26 Wrote:hentai23 -
after i get all my comics sorted my next adventure with Angelscry's Advance launcher will be to get my games going ... I know earlier in this thread you had some issues with 2 Advance Launcers installed - any advice for someone going to do that? follow the youtube? wiki? etc .... ?
Here is a Youtube tutorial :
http://www.youtube.com/watch?v=_gMFJcxdcEg
hentai23 Wrote:dugan id wait till angel makes his specific comic addon , since his current adv sux for comics management and well ....just about anything comics xD
Just to remind you hentai23, that Advanced Launcher is not for management stuff it is just an application launcher. I do not understand why you said it "sux" because it does not do well things it is not supposed to do.
dugan26 Wrote:ah - i didnt know he wsa working on one ...
No release date yet because not even one line of code written. Do not wait this add-on before next year.
yeah thats why xD ....was just jokin ....we know it doesnt support those things xD
p.s: next year omg ...thats....another month and a half xD
so you plan on releasing this on january? xD
hentai23 Wrote:yeah thats why xD ....was just jokin ....we know it doesnt support those things xD
To be honest, I don't know how many time it will take me to make it.
well tbh ive found a inbetween solution
listen to me angel and just add one new option to adv
http://comicrack.cyolito.com/forum/13-sc...cover-page
ive already tried it does what it sez perfect same filenames only difference is .tbn instead of the archive extension xD ,
it will autoextract the first image aka the cover of the archives you selected to the directory the archives are contained in, so if you could add an option to auto scan that folder or add a default .tbn folder for thumbs and fanart selection option for launcher items to scrape from locally instead of online, itd solve the thumbs and fanart problem atleast till you get the complete addon up and running
Anyone got a new link to the Comic Backdrops ?
The link on the first page/post has expired..
Angel-
Can you point me to a help screen that gives me directions on installing a second version of Advance Launcher - I want to start loading up my games (and am already using it for Comics) ... let me know thanks
dugan26 Wrote:Angel-
http://forum.xbmc.org/showpost.php?p=933...tcount=258
ugh - sorry pal ... thanks -
dugan26 Wrote:thanks again! -
Question: I am about to build a new box (HTPC) and going to move my XBMC over to it. Is there a way to copy over all the work i have done in advance launcher? All comics art, info files, etc .... ?
Hi -
Anyone know how this can be done?
dugan26 Wrote:Hi -
Depend how different will be your new HTPC system from the older one.
If all the paths to comics, thumbs and fanart images on your new HTPC are EXACTLY the same than for the ones on you older system, all you have to do is to make a backup of your actual launchers.xml file into your XBMC userdata directory and replace the one into your new HTPC system.
If paths are different, you have 2 solutions :
- Edit your launchers.xml path and use a text editor that have automatic replace feature, and replace your old system paths by your new HTPC system path.
- Make a backup for each launchers of all your comics into NFO files (using "Export items data to .nfo files" option). Make sure that all you thumbs and fanarts images have the same name than your comics files. Then copy all your files (comics, nfo, thumbs and images) into your new HTPC system. Then recreate launchers and do scans with all scrapers deactivated (will normally automatically import thumbs and fanart) and then use the "Import items data from .nfo files" optino to quickly import all the comics information.
