Full Version: [MOD] New SubMenu (0.2)
Pages: 1 2
New for SubMenu (0.2)
better integration in to Aeon (Stark)
home page animation now works with SubMenu 0.2
new sub menu for Shutdown
switch to trun off/on the home page animation (see the bottom of the post for the code)
Things to note..
with the new integration in to Aeon some of the submenu names have been change to fit better see list below
Browse Files is Files
Video,Music Plugins is Plugins (not localize)
Recently Added *** are all now NEWEST (not localize)
Music Videos is Videos
Shutdown Timer Is Timer (not localize)
Reload App is Reload (not localize)
Bugs
i need to find a smaller word for compilations so if you know of one Plzz let me know....
Refreshing the skin when in the submenu view will some times make the menu disappear
moving up or down like you are going back to the main menu wil fix this most of the time Wink
here are some pics
Download the mod here
rapidshare - http://rapidshare.com/files/217082143/su...AS0.91.zip
mediafire - http://www.mediafire.com/?m2aztdywqnn
SubMenu (0.2) will be added to the mod pack once all bugs have been fixed. Nerd
Edit:
*** You need to add this if you are not updating from the old mod *****
open Includes.xml and add the code below
<include file="Includes_sebmenu.xml" /><!-- <<<<<< Add this -->
Edit:
code below is to add a sub menu on/off switch to Settings >> Customise >> Advanced >> Home
( if you are updating from the old mod you do not need to add the code below as you have it from the older one)
(this code is not needed to make the mod work, it's so you can turn it offWink)
Open Customisation.xml
find:
        <control type="radiobutton" id="501">
            <include>Objects_SettingsDefaultRadioButton</include>
            <label>31295</label>
            <onclick>Skin.ToggleSetting(bighome)</onclick>
            <selected>Skin.HasSetting(bighome)</selected>
        </control>
then add this code just below it
<!-- ADD this> >>>>> -->
        <control type="radiobutton" id="503">
            <label>Sub Menu... (genre, year, etc)</label>
            <onclick>Skin.ToggleSetting(CustomMenuSub)</onclick>
            <selected>!Skin.HasSetting(CustomMenuSub)</selected>
        </control>
<!-- <<<<< ADD this -->
Edit:
Adding a switch to trun off the home page animation
open Includes_sebmenu.xml and Find
<include name="homesubmenu_anim">
    <!-- OnUp -->
    <control type="button" id="324">
        <visible>Control.IsVisible(330)+!Skin.HasSetting(lowermainmenu)</visible>
        <include>homesubmenu_but</include>
        <onfocus>SetFocus(325)</onfocus>
        <onfocus>Skin.SetBool(submenu)</onfocus>
    </control>
        <visible>Skin.HasSetting(lowermainmenu)</visible>
        <onfocus>SetFocus(300)</onfocus>
        <onfocus>Skin.Reset(lowermainmenu)</onfocus>
    </control>
    <!-- OnUp end -->
    <!-- Ondown -->
    <control type="button" id="322">
        <visible>Control.IsVisible(330)+Skin.HasSetting(lowermainmenu)</visible>
    </control>
        <visible>!Skin.HasSetting(lowermainmenu)</visible>
        <onfocus>Skin.SetBool(lowermainmenu)</onfocus>
    </control>
    <!-- Ondown end -->
    <!-- OnUp sub -->
    <control type="button" id="321">
        <onfocus>Skin.Reset(submenu)</onfocus>
    </control>
    </control>
    <!-- OnUp sub end -->
    <!-- Ondown sub -->
    <control type="button" id="320">
    </control>
    </control>
    <!-- Ondown end -->
    <!-- Windowopen -->
    <control type="button" id="323">
        <visible>Control.Isvisible(330)</visible>
        <visible>Skin.HasSetting(submenu)</visible>
        <!-- <onfocus>Skin.Reset(submenu)</onfocus> -->
    </control>
        <visible>!Control.Isvisible(330)</visible>
    </control>
        <visible>!Skin.HasSetting(submenu)</visible>
    </control>
    <!-- Windowopen -->
</include>
replace with
    <!-- OnUp -->
        <visible>Control.IsVisible(330)+!Skin.HasSetting(lowermainmenu)|Control.IsVisible(330)+Skin.HasSetting(CustomMenuanimation)</visible>
    </control>
        <visible>Skin.HasSetting(lowermainmenu)+!Skin.HasSetting(CustomMenuanimation)</visible>
    </control>
    <!-- OnUp end -->
    <!-- Ondown -->
        <visible>Control.IsVisible(330)+Skin.HasSetting(lowermainmenu)|Control.IsVisible(330)+Skin.HasSetting(CustomMenuanimation)</visible>
    </control>
        <visible>!Skin.HasSetting(lowermainmenu)+!Skin.HasSetting(CustomMenuanimation)</visible>
    </control>
    <!-- Ondown end -->
    <!-- OnUp sub -->
    </control>
    </control>
    <!-- Ondown sub -->
    </control>
    </control>
    <!-- Ondown end -->
    <!-- Windowopen -->
    </control>
    </control>
    </control>
    <!-- Windowopen -->
</include>
Now for the switch open Customisation.xml
    </control>
    <control type="grouplist" id="12">
replace with
        <control type="radiobutton" id="504">
            <label>Home menu animation...</label>
            <onclick>Skin.ToggleSetting(CustomMenuanimation)</onclick>
            <selected>!Skin.HasSetting(CustomMenuanimation)</selected>
        </control>
    </control>
looks and works great... great work Nod
Wow this works amazing. Thanks for the effort. Download this guys you will love it.
One suggestion. My nature is to press down again to get back to the main menu. How would I go about reversing that? Basically I have no need to move the menu bar down and up. I liked your previous version of the mod that had up and down switching the menu.
wow great update.
Only one thing pushing up pulls the submenu, pushing down should exit submenu and not pushing up again. Just doesn't feel as intuitive this way.
EDIT: To slow Smile but its nice to see that other think the same way i do.
@krypt2nite
i will have to look in to it i will get back to you
ok to make it exit submenu on up or down and not do the animation
and find
    <!-- OnUp sub -->
    </control>
    </control>
    <!-- Ondown sub -->
    </control>
    </control>
    <!-- Ondown end -->
and replace with
    <!-- OnUp sub -->
    </control>
    <!-- Ondown sub -->
    </control>
    <!-- Ondown end -->
i have not tested this but it shold workWink
It works perfectly. Thanks. How do I make it also do it on the main menu. So I press down and it will also show the genre menus etc.
krypt2nite
    <!-- OnUp -->
    </control>
    </control>
    <!-- OnUp end -->
    <!-- Ondown -->
    </control>
    </control>
    <!-- Ondown end -->
and replace with
    <!-- OnUp -->
    </control>
    <!-- OnUp end -->
    <!-- Ondown -->
    </control>
    <!-- Ondown end -->
Not tested but should workNod
Works perfect. This is great man, thanks for the assistance.
I can't get this to work with 0.91 - nothing is focused on boot and left, right, up and down do nothing.
my bad you need to add
to Includes.xml
that colorful background is cool... where did you get it, or can you post?
Adding a switch to trun off/on the home page animation (see the bottom of the 1st post for the code)
Silly question, but since they both have somewhat similar file structures, do you think this would work with the Horizonz skin?
Pages: 1 2
