2009-04-04, 01:31
Im having problems getting a xbmc working with my xorg.conf on an intel GMA 3000 intergrated. I can start X at the correct resolution but xbmc just fails to start (black screen).
I was wondering if there is anybody that has a working xorg.conf for this card or similar that could pass on a few pointers. eg. modules loaded, any options set and any packages install/compiled to get it working.
My xorg.log doesnt suggest anything is going wrong.
I've yet to check the xbmc.log, will report on that soon.
I was under the impression that on Intrepid, installing xorg also brings down the required intel drivers. Is this true or do I have to install additional drivers (similar to using nvidia proprietory).
I have a feeling this is an OpenGl issue(driver/modules). From intel, It is suggested that the GMA 3000 supports OpenGL 2.1. (Not to be confused with the GMA 3100 which is actually a scaled down mobile with only OpenGL 1.4)
see http://en.wikipedia.org/wiki/Intel_GMA#T...d_chipsets
My setup is a CLI Intrepid with xorg, build system and xbmc built from SVN.
If required, please ask for additional information and how to get it.
zepp
zepp
