Full Version: Film studio Flag Icons - Post new ones here!
scrolling Wrote:I have a request for these three. Thanks.
No problem:
BTW, Fern, I was unable to add those to your site:
Fatal error: Class 'readme' not found in /mnt/w0110/d07/s13/b023e69b/www/fernferret_com/xbmc/mediaflags/add.php on line 113
Cheers
Just a great place to get studio icons: http://www.customaniacs.org/forum/forumd....php?f=544
Sranshaft Wrote:Just a great place to get studio icons: http://www.customaniacs.org/forum/forumd....php?f=544
Thanks mate, the site is great! Most of them we already have, but there's plenty of logos that could be improved Smile
Cheers
FernFerret Wrote:paul:
I'll make sure it does this weekend, I haven't seen any new updates since he last updated the XML which was a while ago i thought...
--FF
Thanks that would be great as i managed to screw up my last revision of Aeon_auriga_lite
And updated the flags.xml without checking before releasing the skin(that will Teach Me not To checkLaugh) Ps keep up the great work your doing and thanks again
If someone could do this one that would be great.
i'll check out that error, that's weird...
EDIT: Fixed that fatal error message. I also added Ladd for ya.
haha yea paul, in these development times, when he changes things my code is dynamicly generated from a snapshot xml build, which is why i put that clause in about it may break your skin Smile
Thanks,
--FF
Ok, converted almost all of those (34 new icons, including Happy Madison), uploading right now.
EDIT/ Done all up to page 9 of that thread. Not all of them are perfect, but the page doesn't allow downloading the PS files easily. Anyway, got to get back to work now. Any volunteers to convert images past page 9?
Cheers
ekim232 Wrote:If someone could do this one that would be great.
Image Here you go
Can someone upload the Babylonian Productions logo from http://forum.xbmc.org/showpost.php?p=320...tcount=207 to the mediaflags page ? I just want to make sure it isn't lost. Thanks.
ccMatrix Wrote:Can someone upload the Babylonian Productions logo from http://forum.xbmc.org/showpost.php?p=320...tcount=207 to the mediaflags page ? I just want to make sure it isn't lost. Thanks.
Thanks for reminding me, done.
A & M Films overlaps almost all studio logos :/
mindweaver Wrote:A & M Films overlaps almost all studio logos :/
You mean it's taken the place of Shout, right? FF, any idea what went wrong? Probably it's the & sign - I guess we should rename it to A and M.
Cheers
Halibutt Wrote:You mean it's taken the place of Shout, right? FF, any idea what went wrong? Probably it's the & sign - I guess we should rename it to A and M.
Cheers
Exactly Smile
It might be the & that confuses xbmc.
yea, i havent gotten a chance to add the bad character checker, i'll go fix that one manually. I have a lot of changes that will be made over this weekend, i'm just really booked right now.
Also in an effort to maintain only two xml files as I am currently doing, I will be updating so that the downloadable package will support only the latest Arugia that djh_ commits, so only the most bleeding edge version, which is what we're all doing here anyways with this project.
--FF
