Full Version: Film studio Flag Icons - Post new ones here!
@ CCMatrix: How often the GIT is updated?
Basically: When I get to it. When I have spare time and there are a few open requests I create another batch. There is no specific timetable.
I had a quick look at the zip you posted and I will have to work almost every single one of them. The only thing that maches the other icons is the width and height of them. They are not correclty using the alpha channel but instead are using grayscale which makes color diffuse effects impossible.
@CCMatrix: Thanx for your reply. I have made some requests in the prescribed form. And regarding those anime studio logos, I hope they are included in your GIT after due correction. They were posted by bambi73 in a separate thread : forum.xbmc.org/showthread.php?tid=70398. Keep up your good work.
Its been 5 months since the last commit to git was made. I have made many requests in the spreadsheet in your github . Are you still working on updates?
Hi i have to question i would love help on,
Colored flags, i have downloaded many sets, and have try ed many ways but i cant seem to get them to work. i am using the Aeon MQ 3 skin xbmc 11.0-pre git: 20120307-b59d0da (compiled mar 7 2012).
Also i am wondering what the proper procedure is to add clearart/ clearlogos to movies , just as they would work in tv shows.
thanx
(2012-04-12, 16:58)KoSHuR Wrote: [ -> ]Hi i have to question i would love help on,
thanx
Ask in the MQ3 thread not here
(2012-04-12, 18:53)Martijn Wrote: [ -> ]
thanx
thanks for the reply but i was told to ask here.
will try again
(2012-04-12, 19:35)KoSHuR Wrote: [ -> ]
thanx
will try again
Then they are wrong. Adding your own studio flags and logos is totally skin dependant.
Each skin has it's methods
(2012-04-12, 19:41)Martijn Wrote: [ -> ]
(2012-04-12, 18:53)Martijn Wrote: [ -> ]Ask in the MQ3 thread not here
will try again
Im On My Way !!!!!!!
Big Grin
(2009-04-05, 14:43)Halibutt Wrote: [ -> ]And three more European majors or almost majors:
I'm planning to do most companies involved in latest European Film Awards, so stay tuned Smile
Cheers
Can you do this one please.
