Full Version: 720x304 not displaying in 2.35
I've got a couple of rips that are 720x304 that should be showing in letterbox 2.35. My display is set to Normal, and I've calibrated the video.
What I get is video that stretched vertically to fill the whole screen. Adjusting my pixel ratio to 1.50 seems to put it back to about the correct ratio, but I'm wondering if I have something setup wrong.
Check the file - it may contain PAR information that is off (XBMC will display this if you press Z once).
PAR shows 1:1 DAR shows 45:19.
Pressing Z didn't show it, but I did. ?
