Full Version: Photo viewer crashes constantly
OSX Version: 10.5.6
Platform: MacBook Pro
Install Method: dmg
SVN Revision: XBMC 8.10 bf1: ATLANTIS
Detailed Instructions to Reproduce the Problem (The more specific the better.)
1. Create a folder called "Photos/Event1/" in ~/Documents
2. Add approximately 500 photos to that folder, JPEG level 10, 1366x768 resolution, sRGB colour space (you wanted precise, right? Smile
3. Install XBMC using the DMG
4. Launch XBMC, opens in a window, all settings are default
5. Select Pictures, change view to thumbnail
6. Navigate to the folder created above
Result: XBMC scans and creates the thumbnails, and after about 3 seconds, crashes completely.
FULL Debug Log http://pastebin.com/m3f482b0e Log
GUI Problems: Other than crashing, none
Skin name: default skin
Playback Problems: n/a
System hardware specs (CPU, RAM, Chipset, etc.)
Model Name: MacBook Pro 15"
Model Identifier: MacBookPro2,2
Processor Name: Intel Core 2 Duo
Processor Speed: 2.16 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 4 MB
Memory: 2 GB
Bus Speed: 667 MHz
Boot ROM Version: MBP22.00A5.B07
SMC Version: 1.12f5
Sudden Motion Sensor:
State: Enabled
MikeD Wrote:OSX Version: 10.5.6
Install Method: dmg
L2 Cache: 4 MB
Memory: 2 GB
Bus Speed: 667 MHz
SMC Version: 1.12f5
State: Enabled
crashreporter log too please.
MikeD Wrote:Sorry: http://pastebin.com/m49f71d40
thanks, update to 9.04.alpha1.
8.10.bf1 (SVN-16366M) uses a non-thread safe libcdio and this is fixed in 9.04.alpha1. It's a random crash, next time you run, it might or might not crash again but sooner or later it will crash.
Thanks. Anywhere in particular I should look for that? It's not listed on the download page, and the link to the dev builds doesn't reference the file you named.
...Mike
Pop over to http://sourceforge.net/projects/xbmc
And go to file downloads from there.
Cheers,
Jonathan
