2009-04-09, 16:50
Hi
I used this script to build xbmc for opensuse 11.0, 64bit:
svn co https://xbmc.svn.sourceforge.net/svnroot.../linuxport
cd linuxport/XBMC
make distclean
CFLAGS="-I/usr/lib64/dbus-1.0/include -I/usr/lib64/glib-2.0/include"
export CFLAGS
./configure --enable-halmount --disable-pulse --prefix=/usr
CFLAGS="-I/usr/lib64/dbus-1.0/include -I/usr/lib64/glib-2.0/include" make
This works fine until recent svn versions. As soon as I try to play mp3 or video files xbmc crashes and I only see strange things on tv. There is nothing in the log file:
16:45:29 T:3636607040 M:2479575040 NOTICE: -----------------------------------------------------------------------
16:45:29 T:3636607040 M:2479575040 NOTICE: Starting XBMC, Platform: GNU/Linux. Built on Apr 9 2009 (SVN:19351)
16:45:29 T:3636607040 M:2479575040 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
16:45:29 T:3636607040 M:2479575040 NOTICE: special://masterprofile/ is mapped to: /var/autologin/.xbmc/userdata
16:45:29 T:3636607040 M:2479575040 NOTICE: special://home/ is mapped to: /var/autologin/.xbmc
16:45:29 T:3636607040 M:2479575040 NOTICE: special://temp/ is mapped to: /var/autologin/.xbmc/temp
16:45:29 T:3636607040 M:2479575040 NOTICE: The executable running is: /usr/share/xbmc/xbmc.bin
16:45:29 T:3636607040 M:2479575040 NOTICE: Log File is located: /var/autologin/.xbmc/temp/xbmc.log
in .xsession-errors I got this:
The XBMC_HOME environment variable is not set.
Creating link /var/autologin/.kde/socket-FILE.
CRITSEC[0x12308e8]: Trying to enter destroyed section.
CRITSEC[0x12308e8]: Trying to leave destroyed section.
ALSA lib pcm_dmix.c:996snd_pcm_dmix_open) unable to open slave
can't create mcop directory
Looks alittle bit strange to me because I'm not running kde or any displaymanager. I start xbmc wrong .xinitrc
Any idea what is wrong?
Should I try a beta nvidia driver? I still use 180.
cd linuxport/XBMC
make distclean
export CFLAGS
