2009-04-10, 15:42
I'm running XBMC compiled from SVN on Ubuntu Intrepid.
Whenever I install a new package via apt-get I get a long list of packages that are "automatically installed and no longer required"
These are all dependencies required for XBMC compilation and were installed via: sudo apt-get build-dep xbmc
Is there anyway to tell apt to shut up already about the XBMC dependencies?
EDIT: Nevermind - I ended up grabbing the output of "no longer required packages" and doing a sudo apt-get install to set them all manually installed - that solved the problem.
EDIT: Oops - no that didn't solve the problem, still have the original issue. WTF?
