Full Version: MusicDB Some entries added not correct
Rev19353 Windows PM3.HD
Settings Music: Fetch album and artist uncheck, Enable tag reading check.
I add a new album Sting - Duetos to my library.
The songs are tagged as:
Artist: Sting
Title: Sting & Annie Lennox - We'll Be Together
Filename: 03 - Sting - Sting & Annie Lennox - We'll Be Together.mp3
After the album is added to the library it shows in the artist section Sting & Annie Lennox as artist but I don´t know why. The correct entry is Sting for the artist.
I check the tags with two different tools
The database one example music file and the debug log as
http://www.mediafire.com/?sharekey=663bf...6e282a0ee8
I hope someone can tell me where the problem is.
Thanks for your help
It has the BAND tag (album artist) set to Sting & Annie Lennox.
Use a real tagging app - foobar2000 is IMO the best out there.
Hello Jonathan,
thanks for your hint.
I change the taggs hours and hours with mediamonkey but I don´t see the Album Artist.
I change the taggs with Foobar2000 and it works correct.
Thank you very much
