Full Version: Cannot setup audio hardware.
In both djh and cf2009 branches.That screen is corrupted.
Let me know of you can replicate it.
I just wanted to switch between analog and digital.Works fine in pm3.
EDIT:
This only happens when you use the shortcuts in audio or video settings.If you go to systems settings it works fine.
to fix this open up SettingsCategory.xml
find (second line)
<defaultcontrol always="true">3</defaultcontrol>
and replace with this
<defaultcontrol>3</defaultcontrol>
CF2009 Wrote:to fix this open up SettingsCategory.xml
find (second line)
I see you fixed that on github.Thank you.
