Full Version: new to linux need some help
I installed the regular ubuntu interpid just to see if i could get my wifi card to work before doing anything els well it did work and it worked right away it said something about athoes driver. My question is when i use the mini ubuntu will it automatically work like the regular ubuntu or will i have to manually install the drivers?
second i couldn't finger out how to connect to the ssh i tried putty but it always failed is there a command i can use to check if i did in fact install openssh ?
This guide should help you: http://help.ubuntu.com/community/SSHHowto
You'll probably get more success with non-XBMC Ubuntu questions over on the Ubuntu forums.
Hope this helps!
The ssh daemon isnt installed by default on ubuntu..
sudo apt-get install ssh
