2009-04-15, 10:36
Pages: 1 2
2009-04-17, 06:26
i want it too and include svt even that it has a script out rather have all .se in one script
2009-07-13, 17:39
I've made a simple script that fetches content from various sites as TV3.no, se, dk and a bounch of others, but it's only using the xml files from the hosting provider, so it's a lot of outdated stuff. If someone are intrested in scraping the correct information from the webpages, you can use this as a base.
I haven't tested it in a month or so, but I guess it should work.
Download:
http://prosjektet.net/xbmc/plugins/Viasat.7z
Download:
2009-08-02, 00:42
I was so exited when I found this script, but it don`t seem to work anymore.
Is there any way you can fix it? I´m running it on an xbox with a fairly new build of xbmc (compiled 2009_05_01).
Thanx
Aavar
Thanx
Aavar
2009-08-02, 10:32
Here is a script that takes SVT play, TV3 and TV6.. http://www.rieter.net/uitzendinggemist/
2009-08-02, 20:01
all works without the one i really wants sverges television
2009-08-02, 22:14
I am also hoping this will be available soon, especially Kanal5 as I cannot find that elsewere... sometimes I wished I lived in Sweden!
2009-08-03, 10:19
andersw Wrote:all works without the one i really wants sverges television
Hit menu and update the SVT chanels from within XOT and they will work again.
2009-12-02, 09:45
Reiter is a really good plugin!
But has anyone heard any news about the swedish channels TV4, Kanal5?
2009-12-08, 09:07
Bump on that...
Plex does have it working so...
Don't take it wrong
Something that grab SVT Play, TV4 Play, TV3, Kanal5 and other common channels would be so great.
*hugs*
Don't take it wrong
*hugs*
2009-12-15, 00:25
McGilljam Wrote:Bump on that...
Don't take it wrong
*hugs*
Xot script does works fine with SVT Play, TV3 but I also miss TV4 and Kanal5 but see the reason according to Xot developer here:
http://forum.xbmc.org/showpost.php?p=449...tcount=586
Apparently Plex developers got contacted by tv4play to have a plugin developed according to their forum.
2009-12-15, 06:43
I made a request for webbtv.se wich is a portal to all the major swedish tv-channels
http://forum.xbmc.org/showthread.php?tid=59130
2009-12-15, 14:28
It seems that there is a Tv4se plugin:
http://code.google.com/p/xot-uzg/issues/...=149&q=.se
I haven't tested it yet but will do tonight.
2010-03-18, 00:50
Any update of this?
I've tried both the Viasat addon and the XOT plugin and sure, they work..
For about 55 seconds, then they stop the stream..
With the XOT plugin I can watch SVT without problems, sometimes the
playback stops but only to buffer up, then it can be played..
So what may be wrong and can someone make an addon that actually works?
2010-04-28, 22:37
VictorV Wrote:I've made a simple script that fetches content from various sites as TV3.no, se, dk and a bounch of others, but it's only using the xml files from the hosting provider, so it's a lot of outdated stuff. If someone are intrested in scraping the correct information from the webpages, you can use this as a base.
Download:
Can`t get this to work. Is there something that I must do?
I use Windows.
It don`t list thing, looks just to be old things... Not updating it self from the web. Norwegian TV3.
Kindly
Petter
Pages: 1 2
