Full Version: [RELEASE] XBMC Controller for PSP (PlayStation Portable)
XBMC Controller V1.1 - By Ooblik
This is a controller for XBMC for the PSP. Written in C and not crappy LUA like the others.
It includes the basic controls and the ability to send messages to the XBOX.
This is an early version so it may be buggy.
To Go To The Menu Press L+R.
[email protected]
Installation
1. Extract "XBMC Controller" to your X:/PSP/GAME/ folder.
2. Edit "config.txt". To match your XBOX IP Address and Webserver Port.
EXAMPLE:
xbox_ip = "xbox";
xbox_port = 80;
xbox_pass = "yourpassword";
3. In XBMC make sure your webserver is enabled.
Changes
1.1
- You can now control password protected webservers. (Thanks to clpetty for bringing this to my attention. XD)
- Added option to reload configuration.
- Controls can now be re-mapped in the configuration file.
DOWNLOAD
Cool!
Thx
Very, very, very cool.
Tell me, how difficult would it be to have something like this where the PSP worked like an xbox controller in one mode, and a webserver in another? I had it config'd using IRShell to do this, but built a htpc w/o IR, so now I have to use the xb1 controller.
It would be very cool to have this feature...just using the eventserver to send up/down/left/right commands?
No luck for me. Just get 80020148 The game could not be started. I am running system software 4.05 if that makes any difference
