Can you only stream onto the Apple TV or is there a way to copy films (AVI,MKV... etc) onto the Apple TV?
You can do it through SSH.
Sorry I'm new to XBMC how do I do that? by the way I'm using Windows XP
Once you installed XBMC and enabled SSH on AppleTV (following tutos that you can find online), you can connect throught ssh to your AppleTV with a software like FileZilla.
... with theses settings :
sftp://IP-of-your-appltv
Login : frontrow
Password : frontrow
After, just drag and drop your files, ...
tintamarre Wrote:Once you installed XBMC and enabled SSH on AppleTV (following tutos that you can find online), you can connect throught ssh to your AppleTV with a software like FileZilla.
Login : frontrow
Password : frontrow
How do I enable SSH?
Hi thanks for the quick reply but is that not only for Mac or can you use it for Windows as well?
I got it sorted using Filezilla thanks Guys
