2009-04-16, 19:10
I've started to create my own dvd ripping facility for XBMC for linux. I was searching everywhere for this feature but for some reason no one has created it.
I was wondering if anyone else would like to help develop this so we can make it a nice feature!!
1st of all I installed dvdbackup onto Ubuntu from the standard repo.
Then as I have no knowledge whatsoever of python I found a simple command line for dvdbackup that worked under terminal:-
dvdbackup -M -o /home/paul(as thats my login home dir)/Videos
This creates a directory taken from the name of the dvd and copies the VIDEO_TS folder into it.
I then checked in XBMC and this found it fine and as the name was correct found the artwork etc and it plays fine.
Then I managed to create a simple default.py file and added my ./xbmc directory under scripts. The file is simply as follows.
I then accessed this script in XBMC and it worked great with a running message next to it until it had completed.
I then moved this default.py into a directory called DVD RIP with a image named default.tbn and put this directory into my ./XBMC/plugins/video directory.
Now I can access this from watch my videos, video plugin.
Here is where I would love someone to help develop.
2 Things.
1. I would love it to show the progress instead of at the moment it just comes up saying LOADING DIRECTORY RETRIEVED 0 ITEMS until compete.
2. There is another command we can add to dvdbackup making the command:-
dvdbackup -M -n NAMEOFTHEMOVIE -o /home/paul/Videos
What i would like is a menu asking the NAMEOFTHEMOVIE so in XBMC we can either use a keyboard or a remote to name the movie correctly so it will then always come up correct.
I have no idea how to even start with these options and of course although we can change the destination to be where we always store our movies it would maybe be nice if we could also ask "Where would you like this movie".
Any Ideas.
import os
os.system("dvdbackup -M -o /home/paul/Videos")
2 Things.
Any Ideas.
