Full Version: [LINUX] Keymap.xml: XSD file
since I've been messing around with my USB-UIRT / Ubuntu / Harmony remote, I ended up learning XSD format and writing a limited one for Keymap.xml.
With a proper editor, it offers autocompletion for elements (keymap/global/remote/<remotebutton>/<XBMCCommands>), and as far as I'm concerned made my life much easier (proper & free editor, not tested with anything else: MS Visual C# Express)
It will report a few errors, since I didn't figure everything out yet, and won't offer completion for gamepads, only for remotes + keyboard. Although every XBMC command / remote and keyboard commands should be there.
Hope it helps anyone.
Download keymap.xsd
Edit: TRAC ticket with attachment
Nice work Smile
Mind making a trac ticket and uploading it there - that way if your server goes down for whatever reason we always have it (eg it's down atm).
Cheers,
Jonathan
No no, the server was not down... I just can't write the links I create. The link is fixed now. The server is a dedicated one, it's not likely it will go down, but I'll create a Trac ticket, you're right.
The XSD is far from complete though, I had never written any XSD file before yesterday... interesting task though, it will be useful to me Smile
