Full Version: Where can I download plugins to FTP to my stable build XBMC?
I was looking for the NBC and CBS plugin. They say to get it from the SVN repoinstaller. I am using a stable build and SVN Installer doesn't work. So I installed the TECH SVN version and SVN installer works for installing the plugins.
However I am getting streaming issues and glitches. I want to use the stable build. Is the SVN built only to work with SVN builds?
I rather just download the plugin and then just FTP it to my e:/dashboard/plugins/video folder manually.
You can also use Installer Passion XBMC script or XBMC Zone plugin which provide usually stable version since it is archive based and not SVN based.
