New to XBMC. Have Atlantis installed but can't get SVN Repo Installer to work. I have enabled programs on main menu but when I browse into programs -> program plugins there sits SVN Repo Installer but selecting does nothing. Also if I go to favorites and select it I end up at a page called SVN Repo Installer but there is nothing on it and no actions to choose from. What am I doing wrong? Thanks.
I think you need to install the SVN version of XBMC to get SVN installer to work.
I've the latest svn installed from ppa repositories and there are 2 identical svn repo installer pages in favorites. Both are empty and useless...
(ubuntu 8.10)
I have to agree on my xbmc (xbox) 4/3/2009 its also broken (good think I always keep two versions of the scripts around....)
qubilist Wrote:I think you need to install the SVN version of XBMC to get SVN installer to work.
Qubilist can you elaborate, what do you mean by install the "SVN version?" I have the version that came with XBMC that I d/l directly from xbmc.org, I haven't downloaded anything else/different. How would I go about installing this SVN version you speak of? Thanks. :confused2:
Google TECH or T3CH XBMC. There is a SVN build and a Stable build. Try using the SVN build.
I am on the phone so i cant check my bookmarks for it.
