Full Version: mounting /dev/sda1 on .mnt failed: invalid argument
Hi All
have an issue running XBMC on a usb key or usb hdd
basically in safe mode i get
found harddisk at /dev/sda
attempting to resume fdrom hibernation...
will mount root from /dev/sda
setting up our squashfs and ext3fs unionfs system...
mount: mounting /dev/sda on /mnt failed: invalid argument
did not find /mnt/rootfs.img
sleeping for 0.5 seconds...
mount root from .dev.sda1...
i have changed everything to use UUID but as you can see its using/dev/sda
i believe the problem is a script in initrd0.img called disk.
it seems to look for hda hdb sda sdb mounting the first drive
this might be my ubuntu installation
i have no idea how to fix this
i have tried extracting editing and packing initrd0.img but it was a compleate failure
any ideas welcome
Steve C
