2009-04-24, 00:01
Wasnt sure where to put this so I guessed here :p
Anyway I read through voinage's excellent tutorial and it got me really interested in developing. Problem is no matter what I done I always got stuck at some point. I'm pretty sure I followed the tutorial exactly, install wireshark etc. I'll elaborate.
Downloaded python 2.6.2 (because it was the one used in the tutorial) but found couldnt use IDLE. Researched this and found it was because of 2 missing dlls (tcl84.dll & tk84.dll). Downloaded those, put in system32, restarted. no dice.
Figured I'd download python 3.0.1. Still no good with IDLE. So after i found pywin32-3.0. Opened, but threw a syntax error at line 17 (the last "print match" line) of test.py used in the tutorial
Then I figured I ask for help
Tell me then if you can, what do you use to develop plugins on windows? (version numbers, programs etc)
Why isnt it working? (XP SP2)
Is it easier to develop in linux?
Also what is wireshark needed for?
I feel like this should be asked in an irc channel but whatever :o
Thanks for any and all inputs
