Full Version: Ejecting a CD
Me again... the wife loves xbmc but complains that she can't eject the audio cd's she is playing in the Mac Mini. Now, I know that if you go to the shutdown option there is a selection there but hardly obvious and she keeps asking me to do it Sad
When you put in an audio cd a play button appears at the bottom right of the screen. Is there any way I can do the same for an eject button. MMM maybe even a set of controls although the remote does just fine.
Thanks heaps!
You could, yes, but that would involve editing the skin. Check Home.xml if you're willing to explore this Smile
You could also map the function to a key as another option - the command is EjectTray.
Welcome to the forums!
Cheers,
Jonathan
