2009-04-26, 15:02
The default key mapping for the MS DVD Remote's big Display button is Fullscreen. To make the xbox kid/grandma friendly, I've remapped that button to xbmc.shutdown() so the same button is used for On and Off.
But just in case someone presses the MENU button while a video is playing and minimize the video, I need an alternative method or button to get the video back to fullscreen. I'm thinking of remapping the PLAY button to a script so that when pressed:
If video is playing and is fullscreen: pause
If video is paused and is fullscreen: play
If video is playing and is not fullscreen: show fullscreen
If video is paused and is not fullscreen: show fullscreen
Basically, the PLAY button will act as a discrete fullscreen button when the video is minimized.
But is there a discrete fullscreen command? DISPLAY is originally mapped to fullscreen and that behaves as a toggle than a discrete fullscreen only command. And keymap.xml shows a togglefullscreen which appears to be the same thing.
If there is no discrete fullscreen command, then I guess I would need a method to detect if the video is fullscreen or not and to run the fullscreen command if the video is minimized.
