Hello,
how exactelly can I get the latest SVN? At the moment I'm using Jaunty and used "apt-get install xbmc" after adding the source... But what do I have to do if I wanted the latest one?
Ok thank you! Do I have to uninstall the old one before doing this?
Probably not a bad idea to uninstall it if you need to ask.
Cool,worked without problems =)
Just two more questions:
What do I have to do if I want to update the SVN? Just delete the XBMC folder and do the hole procedure again?
And how can I create a shortcut so I don't have to go to the terminal and enter xbmc?
1. "svn up". Then continue with step4.
2. google is your friend.
TheUni
theuni Wrote:1. "svn up". Then continue with step4.TheUni
What is step 4? I followed this:
Download, compile, and install XBMC from source
NEXT STEP
# svn checkout
https://xbmc.svn.sourceforge.net/svnroot...xport/XBMC
In case of Hardy, you will get a certificate warning, accept it permanetly by pressing „P”. Wait for downloading XBMC source files, might takes long time, depend on your Internet connection.
NEXT STEP
# cd XBMC
Then configure, compile, and install XBMC:
NEXT STEP
# ./configure --prefix=/usr --disable-pulse
NEXT STEP
# make -j2 (Please note: use only „make”, if you don’t have a dualcore CPU)
This is again, can take quite some time, depending on your CPU speed.
NEXT STEP
# sudo make install
You only need to "svn checkout(co)" once. After that you can just "svn update(up)" to get changes. It would probably do you well to read some on the SVN documentation so you understand what's going on and don't think that it's magic.
And one last question =) How can i check which SVN Version I'm currently using?
I know one way... In the Shutdown menu, accessable from the Home Screen, select "i", Information.
lixe Wrote:And one last question =) How can i check which SVN Version I'm currently using?
found also from beginning of ~/.xbmc/temp/xbmc.log
11:40:12 T:1537271776 M:2559393792 NOTICE: Starting XBMC, Platform: GNU/Linux. Built on Apr 27 2009 (SVN:19737M)
svn info shows version in local svn copy.
Ah ok, I just found out that I have to go to the folder XBMC and execute "svn up". Do I have something else to do like "make install" or anything?
To get build and install the latest updates,
1. Get latest changes:
svn up
2. Configure options:
3. Compile the changes (-j2 only for dual core):
make -j2
4. Install the updated version:
sudo make install
Step 2 isn't required every time, so you can skip it if you are just doing small update.
