crackerbox Wrote:don't know if someone said this or not, but I did a hard drive install with the RC1 and was having the same issue (Nvidia 8200 igp video)
I found the fix somewhere on the forum.
What I did was select XBMC (safe mode) by hitting escape at the boot options.
Then I logged in with xbmc/(password)
Then i ran the nvidia-xconfig as root:
once I rebooted all was well.
Just FYI I took a different approach that worked with some tweaking.
1. I could boot from the DVD into Nvidia mode without any major issue.
2. I installed to HD but then got boot to black on my HDTV.
3. Discovered that there was no xorg.conf in /etc/X11/ so I booted the DVD again to see if there was one, which there was.
4. I SFTP'd into the box and copied the xorg.conf. Then rebooted off the HD, put the xorg.conf into /etc/X11/ and was up and running.
Still needed a variety of tweaking, but was able to get XBMC up and running that way.
