Is it just me or do MC360s File Browser Dialogs no longer appear correctly?
Also the Add Source dialog opens but no controls receive focus.
I'm using the latest MC360 from SVN with Babylon Beta1.
Can anyone confirm?
it's been confirmed.
its been like this for the last few T3CH builds. best workaround for adding sources is to switch to the PMIII skin, setup sources, then switch back to mc360.
I don't suppose anyone knows the exact cause of the problems? For instance an approximate revision that something was changed?
Thankfully this is a small bug that can be worked around by using another skin for source adds.
I really hope that we will be able to continue to use MC360. Its still my favorite skin even compared to the newer ones.
Ok I took the time to fix all the issues get it here
MC360_XBMC-Rev2159-11thMay2009.zip
here are the ones that needed changing
Quote:Revision: 2159
Author: jezz_x
Date: 5:32:40 AM, Monday, 11 May 2009
Message:
Fixed : problems with the skin since the removal of old skin fall back code in XBMC
Modified : /MC360/PAL/CommonViewTypes.xml
Modified : /MC360/PAL/Defaults.xml
Modified : /MC360/PAL/DialogMediaSource.xml
Modified : /MC360/PAL/DialogVideoInfo.xml
Modified : /MC360/PAL/FileBrowser.xml
Modified : /MC360/PAL/MyMusicPlaylist.xml
Modified : /MC360/PAL/VideoOSDBookmarks.xml
Modified : /MC360/PAL/VisualisationPresetList.xml
Modified : /MC360/PAL16x9/CommonViewTypes.xml
Modified : /MC360/PAL16x9/Defaults.xml
Modified : /MC360/PAL16x9/DialogMediaSource.xml
Modified : /MC360/PAL16x9/DialogVideoInfo.xml
Modified : /MC360/PAL16x9/FileBrowser.xml
Thanks for taking the time, Jezz_X.
vvvvv No need to ask him. He does heaps of work for xbmc and the last thing anyone wants is for him to get sick of people bugging him about it and stop caring. Just watch and wait, he'll show everyone when he's ready.
Thank you very much Jezz_X
Looking forward towards the 360 skin with the updated blades...that is if you are still working on it??
i have an issue with mc360 freezing after it plays the last song in a playlist. when it returns to the file list, it freezes.
can someone test it out?
