2009-04-28, 10:55
Pages: 1 2
2009-04-28, 10:58
Movies need to be stored in individual folders, in a subdirectory called "extrathumbs" and you have to create the thumbs yourself as jpeg's (or with some automated program). Like so:
F:\Movies\Amercan Pie\extrathumbs\thumb1.jpg
F:\Movies\Amercan Pie\extrathumbs\thumb2.jpg
2009-04-28, 11:05
I think the additional folder was a mistake. 2 files compared to a folder that makes library updates irritating..
XBMC now scans each one of these in for me as a library item matching them with a movie called Extras. lol
2009-04-28, 11:09
LaTropa64 Wrote:Movies need to be stored in individual folders, in a subdirectory called "extrathumbs" and you have to create the thumbs yourself as jpeg's (or with some automated program). Like so:
Yeah that's how djh explained it himself here: http://forum.xbmc.org/showpost.php?p=323...stcount=66
I couldn't try this yet coz I used file level until now. But this view really is a good reason to move everything to folder level. Is there some tool out there doing all the renaming, copying etc for me so I can just provide my file level folders and click a button? Or do I have to write one myself?
2009-04-28, 11:13
I think it's a cool feature but I'm just not in the mood to update 1,000+ movies in my library with two new thumbnails so, when I get around to it, I'll be hacking the view to just display a larger poster image or the fanart.
2009-04-28, 11:20
LaTropa64 Wrote:I think it's a cool feature but I'm just not in the mood to update 1,000+ movies in my library with two new thumbnails so, when I get around to it, I'll be hacking the view to just display a larger poster image or the fanart.
You can already choose to show the fanart instead of thumbs ;-) Just go to the menu where you can switch the views and go right a couple of times to the option where you can change the mode (which is on "Thumbs" by default).
2009-04-28, 11:22
2009-04-28, 11:23
Montellese Wrote:You can already choose to show the fanart instead of thumbs ;-) Just go to the menu where you can switch the views and go right a couple of times to the option where you can change the mode (which is on "Thumbs" by default).
I posted too soon. I'll have to look for that option. That would work too. Thanks for the info.
2009-04-28, 11:26
LaTropa64 Wrote:I posted too soon. I'll have to look for that option. That would work too. Thanks for the info.
No problem I found it by accident yesterday when I checked the options for multiplex view coz I didn't like the 2 black spaces on my screen
I can't provide you with the exact names of the options though coz I'm at work atm.
2009-04-28, 11:26
So all we need to do is make a folder call extra and the copy the pige inthere?would you try to give a exsample ( like filename etc )
2009-04-28, 11:32
Latropa; how do you make the skin only show 1 flag?
2009-04-28, 11:39
Probably he hasn't set the other flags in the <studio> tag in the NFO.
2009-04-28, 11:42
I made this, only kept the info i think is important the rest is under fullscreen info and added the plot, scrolling.
The edited file:
http://pastebin.com/m2e819601
just copy and past in your Viewtype_Multiplex.xml
Sorry for the past bin but i can't upload files from work =\
The edited file:
2009-04-28, 11:43
2009-04-28, 11:43
Montellese Wrote:No problem I found it by accident yesterday when I checked the options for multiplex view coz I didn't like the 2 black spaces on my screen
Hmmm... It doesn't seem to be working for me.
I'm not sure what I'm doing wrong.
Montellese Wrote:Probably he hasn't set the other flags in the <studio> tag in the NFO.Yep, I haven't got around to updating all my movies with the studio hack so I just turned off "default icons for media flags" in the advanced aeon options.
Pages: 1 2
