2009-04-29, 11:29
2009-04-29, 12:53
from wiki (http://www.xbmc.org/wiki/?title=InfoLabels):
Fanart.Image Fanart image for the parent TV Show
Listitem.Property(Fanart_Image) Fanart image for the selected item
2009-04-29, 13:02
Can that be added directly to lets say MyVideoNav.xml, or is it something I have to add to includes.xml?
2009-04-29, 13:05
It does not have to be in includes.xml.
2009-04-29, 13:10
So will this work for includes
<include name="CommonFanart">
<control type="image">
<posx>0</posx>
<posy>0</posy>
<texture>Listitem.Property(Fanart_Image)</texture>
<width>1280</width>
<height>720</height>
<aspectratio>stretch</aspectratio>
</control>
<posx>0</posx>
<posy>0</posy>
<width>1280</width>
</control>
2009-04-29, 13:16
crap sorry thought you typed DOES. BRB testing now.
EDIT: No idea where to add it. any suggestions?
Code: http://pastebin.ca/1407233
2009-04-29, 13:36
depends on where you want it..
as xbmc layers the items from top of xml to backmost layer in the UI.
If you want to have it as a background, then put it first in the xml
2009-04-29, 17:48
OK I added this to the beginning of the window coding:
<control type="largeimage">
<posx>0</posx>
<posy>0</posy>
<width>1280</width>
<aspectratio>scale</aspectratio>
<visible>Listitem.Property(Fanart_Image)</visible>
</control>
I now get this:
Any suggestions on what I am doing wrong?
Got it!
Not it's got working fanart just needed to change the code to <info>Listitem.Property(Fanart_Image)</info>
and rearrange the window a bit but it works!
<posx>0</posx>
<posy>0</posy>
<width>1280</width>
</control>
I now get this:
Got it!
2009-04-29, 17:58
where exactly have you put it?
remember that it won't show if you have something on top of it that is not transparent.
and it should be within the <controls> tags. just treat it like any other image control
2009-04-29, 18:00
I did an edit
