Full Version: Library not working in newer SVNs
Ever since I started using the VDPAU features in the mainline linuxport, it seems like the Library features don't quite work like they should anymore. If I turn off the library, I can see the content (including cover art) just fine, but with library on, nothing happens when I click on a Genre, for example.
Has anyone seen this as well? Or even a straight forward solution for it?
If you used the VDPAU branch, you'll need to remove your library database, as there were updates in mainline that thus did not make it into your db.
