Full Version: xbmc-vdpau-vdr build error
I'm using the archvdr svn to compile XBMC with vdr support on Arch Linux. Unfortunately I'm stuck here Blush
[jacked@noahs-arch ../Goom/goom2k4-0] $ aclocal
configure.in:22: warning: macro `AM_PATH_XMMS2' not found in library
configure.in:29: warning: macro `AM_PATH_SDL2' not found in library
[jacked@noahs-arch ../Goom/goom2k4-0] $ ./autogen.sh --enable-static --with-pic
libtoolize (GNU libtool) 2.2.6
Written by Gary V. Vaughan <[email protected]>, 2003
Copyright (C) 2008 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
m4/xmms.m4:17: warning: underquoted definition of XMMS_TEST_VERSION2
m4/xmms.m4:17:   run info '(automake)Extending aclocal'
m4/xmms.m4:17:   or see http://sources.redhat.com/automake/automake.html#Extending-aclocal
unknown channel m4UBST_NOTMAKE(HAVE_XMMS_FALSE)
obsolete at /usr/share/autoconf/Autom4te/Channels.pm line 546
    Autom4te::Channels::msg('m4UBST_NOTMAKE(HAVE_XMMS_FALSE)\x{a}obsolete', 'configure.in:29', 'warning: The macro `AC_TRY_RUN\' is obsolete.\x{a}You should run ...') called at /usr/bin/autom4te line 1024
aclocal: autom4te failed with exit status: 1
I hope that somebody can help me with this error.
Thanks in advance!
