Full Version: [AppleTV] Lost library after upgrading to Babylon on ATV
I upgraded from Atlantis to Babylon so I could play .ogg files but in the process seem to have lost a pretty extensive video library.
I’ve tried to re-scan, it then flashes for a second, something about scanning and then nothing.
I saw on another post that this was solved by changing a file, but don’t know which one what to delete?
Any help appreciated.
I’m using ATV 2.3.1
Please grab your video database file (MyVideos34.db) from UserData/Database and save it so that we can reproduce the problem. I'll PM you an email address to send it to.
Once done, delete that file and then rescan and you should be away.
Cheers,
Jonathan
this happened to me as well, not upgrading, but on babylon and with atv 2.3.1.
i didn't have a library to start with so i simply deleted said
~/Library/Application Support/XBMC/userdata/Database/MyVideos34.db
and tried to scan again and it worked just fine.
the trouble seems to be:
13:43:48 T:2684407808 M: 32600064   ERROR: Error attempting to update the database version!
13:43:48 T:2684407808 M: 32604160   ERROR: Can't update the database MyVideos34.db from version 22 to 25
13:43:48 T:2684407808 M: 32591872   ERROR: SQLite: SQL error or missing database
just thought i'd share.
V
fixed in svn and for 9.04 release Smile
