2009-05-05, 04:54
I've been battling for several evenings trying to figure out how I can run XBMC on Ubuntu, with an ATI graphics card connected via DVI to a 1280x1024 monitor and via component video to a 1920x1080 projector. All I want to do is be able to launch XBMC so it displays on the projector.
I have the screens setup (using the Screen Resolution utility), so that both screens are showing the correct resolution. That's a pain in itself, since whenever you launch anything, the window appears on the projector, not on the monitor.
I launch XBMC and in Appearance->Resolution I can scroll through all the xrandr settings for both the monitor and the projector. So I choose COMPONENT_VIDEO 1920x1080. When I do this, XBMC appears to change the display settings to mirrored (vs independent) and all I see is the XBMC display shrunk on both the monitor and projector.
How do I just run XBMC on the 1920x1080 screen? I thought the wmctrl idea here http://forum.xbmc.org/showthread.php?tid=36305 might help, but no luck. Seems that there is only one X display (:0.0) even though I have independent outputs to the monitor and projector.
Any help appreciated. I had this running fine on Vista, except the OpenGL approach can't reliably decode HD movies - I was hoping this would work under Linux, but I have more fundamental problems
Anthony
Anthony
